Autor Tema: ¿cual es la temperatura máxima de Northbridge de una placa base msi970a-g43  (Leído 2578 veces)
christian.retamal.h
  • christian.retamal.h no ejerce ninguna influencia.
Saludos, quiero saber cual es la temperatura máxima del Northbridge de mi motherboard. En indle alcanza los 50 ºC y viendo un vídeo o escuchando música 65º. La he visto alcanzar los 75º.
Pongo el detalle:
CPU-Z
Binaries
CPU-Z version   1.76.0.x64
Processors
Number of processors   1
Number of threads   8
Timers
     ACPI timer   3.580 MHz
     HPET timer   14.318 MHz
     Perf timer   14.318 MHz
     Sys timer   1.000 KHz
Processors Information
Processor 1   ID = 0
     Number of cores   8 (max 8)
     Number of threads   8 (max 8)
     Name   AMD FX-8150
     Codename   Zambezi
     Specification   AMD FX(tm)-8150 Eight-Core Processor
     Package    Socket AM3+ (942)
     CPUID   F.1.2
     Extended CPUID   15.1
     Core Stepping   OR-B2
     Technology   32 nm
     TDP Limit   124.8 Watts
     Core Speed   3869.8 MHz
     Multiplier x Bus Speed   18.0 x 215.0 MHz
     Rated Bus speed   2579.8 MHz
     Stock frequency   3600 MHz
     Instructions sets   MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA4
     L1 Data cache   8 x 16 KBytes, 4-way set associative, 64-byte line size
     L1 Instruction cache   4 x 64 KBytes, 2-way set associative, 64-byte line size
     L2 cache   4 x 2048 KBytes, 16-way set associative, 64-byte line size
     L3 cache   8 MBytes, 64-way set associative, 64-byte line size
     FID/VID Control   yes
     Min FID   7.0x
     # of P-States   7
     P-State   FID 0x1A - VID 0x0B - IDD 18 (21.00x - 1.412 V)
     P-State   FID 0x17 - VID 0x0B - IDD 18 (19.50x - 1.412 V)
     P-State   FID 0x14 - VID 0x14 - IDD 12 (18.00x - 1.300 V)
     P-State   FID 0x11 - VID 0x1A - IDD 11 (16.50x - 1.225 V)
     P-State   FID 0xB - VID 0x25 - IDD 8 (13.50x - 1.087 V)
     P-State   FID 0x5 - VID 0x2F - IDD 7 (10.50x - 0.962 V)
     P-State   FID 0x10C - VID 0x37 - IDD 5 (7.00x - 0.862 V)
     PStateReg   0x800001B5-0x0000161A
     PStateReg   0x800001B5-0x00001617
     PStateReg   0x80000176-0x00002814
     PStateReg   0x8000016A-0x00003411
     PStateReg   0x80000153-0x00004A0B
     PStateReg   0x80000141-0x00005E05
     PStateReg   0x8000012D-0x00006E4C
     PStateReg   0x00000000-0x00000000
     Package Type   0x1
     Model   00
     String 1   0x0
     String 2   0x0
     Page   0x0
     Base TDP   14 Watts
     Boosted P-States   2
     Max non-turbo ratio   18.00x
     Max turbo ratio   21.00x
     TSC   3869.8 MHz
     APERF   3870.0 MHz
     MPERF   3870.0 MHz
     Attached device   PCI device at bus 0, device 24, function 0
         100   00000000 00000000 00000000 00000000
         110   00000000 00000000 00000000 00000000
         120   00000000 00000000 00000000 00000000
         130   000000C1 00000000 00000000 00000000
         140   00000000 00000000 00000000 00000000
         150   00073100 00000000 00000000 00000000
         160   00000000 00000000 00000400 0066E066
         170   00000109 00000000 00000000 00000000
         180   00000000 00000000 00000000 00000000
         190   00000000 00000000 00000000 00000000
         1A0   80000003 00000000 00000000 00000000
         1B0   00000000 00000000 00000000 00000000
         1C0   00000000 00000000 00000000 00000000
         1D0   00000000 00000000 00000000 000000FE
         1E0   00000000 00000000 00000000 00000000
         1F0   00000000 00000000 00000000 00000000
     Attached device   PCI device at bus 0, device 24, function 1
         100   00000000 00000000 00000000 00000001
         120   00000000 00000045 00000000 00000000
         130   00000000 00000000 00000000 00000000
         150   00000000 00000000 00000000 00000000
         160   00000000 00000000 00000000 00000000
         170   00000000 00000000 00000000 00000000
         1A0   00000000 00000000 00000000 00000000
         1D0   00000000 00000000 00000000 00000000
     Attached device   PCI device at bus 0, device 24, function 2
         100   00000000 00004359 00000000 00000000
         110   00000103 00000000 044CA424 0CE00F41
         120   00378B0C 00000000 00000000 00000000
         130   896A5541 34A8F4FA D6E4BAC6 EF83FFA8
         140   00000000 00000000 00000001 00000109
         160   00000000 01F83EE0 00000000 00000000
         170   00000000 00000000 00020000 18400400
         180   000000A0 00800004 33000000 00020000
         190   0B010000 0F580892 8D0F4007 00000000
         1A0   031D0200 00000000 00000000 00000000
         1B0   0FC39101 480F7D26 00000000 00000000
     Attached device   PCI device at bus 0, device 24, function 3
         140   00A11755 00000055 0000C12A 00000000
         160   C00A0FFF 00000000 C00A0FFF 00000000
         170   C00A0FFF 00000000 00000000 00000009
         180   017003E3 00000000 08000210 00000008
         190   00000000 00000000 00780400 00000000
         1A0   00034104 00000000 00000000 00000000
         1B0   3020B323 00000000 00141000 00000000
         1C0   00000000 0003CCCC 00000000 00000100
         1D0   00000000 00000000 002B170F 00000000
         1E0   00000000 80001387 00000000 00000000
         1F0   00080000 00000000 00000000 0000074F
     Attached device   PCI device at bus 0, device 24, function 4
         100   00000000 00000321 00000000 00B401E2
         110   000FE001 00000000 0107000B 00000000
         120   00000000 00000000 00000500 00000000
         140   10623AFF 0000030C 20A2FC79 000006DA
         150   00000869 00E1BFB4 00000000 00000008
         160   00600F12 00000001 00000000 00000477
         180   E000530F 00001004 00000000 00000000
         1A0   00000001 00000000 00000000 00000000
         1B0   C3B56C81 C3B56C81 003A01FB 00000000
         1C0   00000000 00000110 00000000 00000090
         1D0   00080000 0000FFFF 00000000 00000000
         1E0   0B6A161A 0B6A1617 0AEC2814 0AD43411
         1F0   0AA64A0B 0A825E05 0A5A6E4C 00000000
     Attached device   PCI device at bus 0, device 24, function 5
         120   00002222 00000000 00009137 00000000
         160   0000740F 00000000 00000000 00000000
         170   00000808 0001D038 00000000 00000000
         190   2233457A 0000000B 00202020 00000000
     Temperature 1   28°C (83°F) [0x1C] (Package)
Chipset
Northbridge   AMD RD9x0 rev. 02
Southbridge   AMD SB910/950 rev. 40
Graphic Interface   PCI-Express
PCI-E Link Width   x16
PCI-E Max Link Width   x16
Memory Type   DDR3
Memory Size   8 GBytes
Channels   Single
Memory Frequency   859.9 MHz (1:4)
CAS# latency (CL)   10.0
RAS# to CAS# delay (tRCD)   11
RAS# Precharge (tRP)   11
Cycle Time (tRAS)   30
Bank Cycle Time (tRC)   42
Uncore Frequency   2364.9 MHz
Memory SPD
DIMM #   1
     SMBus address   0x53
     Memory type   DDR3
     Module format   UDIMM
     Manufacturer (ID)   Corsair (7F7F9E00000000000000)
     Size   8192 MBytes
     Max bandwidth   PC3-12800J (800 MHz)
     Part number   CMZ8GX3M1A1600C10
     Serial number   00000916
     Number of banks   8
     Nominal Voltage   1.50 Volts
     EPP   no
     XMP   yes
     XMP revision   1.3
     AMP   no
JEDEC timings table   CL-tRCD-tRP-tRAS-tRC @ frequency
     JEDEC #1   6.0-7-7-17-24 @ 480 MHz
     JEDEC #2   7.0-7-7-19-27 @ 560 MHz
     JEDEC #3   9.0-9-9-25-35 @ 720 MHz
     JEDEC #4   10.0-10-10-27-39 @ 800 MHz
XMP profile   XMP-1600
     Specification   PC3-12800J
     Voltage level   1.500 Volts
     Min Cycle time   1.250 ns (800 MHz)
     Max CL   10.0
     Min tRP   12.50 ns
     Min tRCD   12.50 ns
     Min tWR   15.00 ns
     Min tRAS   33.75 ns
     Min tRC   50.63 ns
     Min tRFC   260.00 ns
     Min tRTP   7.50 ns
     Min tRRD   7.50 ns
     Command Rate   2T
XMP timings table   CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
     XMP #1   6.0-7-7-17-25-2T @ 480 MHz (1.500 Volts)
     XMP #2   10.0-10-10-27-41-2T @ 800 MHz (1.500 Volts)
Monitoring
Mainboard Model   970A-G46 (MS-7693) (0x000003D6 - 0x12737B20)
LPCIO
LPCIO Vendor   Fintek
LPCIO Model   F71889A
LPCIO Vendor ID   0x1934
LPCIO Chip ID   0x1005
Hardware Monitors
Hardware monitor   Fintek F71889A
     Voltage 0   3.28 Volts [0xCD] (+3.3V)
     Voltage 1   1.35 Volts [0xA9] (CPU VCORE)
     Voltage 2   2.21 Volts [0x8A] (VIN2)
     Voltage 3   1.29 Volts [0x6E] (VIN3)
     Voltage 4   3.32 Volts [0x4F] (+5V)
     Voltage 5   14.96 Volts [0xAA] (+12V)
     Voltage 6   3.31 Volts [0xCF] (VIN6)
     Voltage 7   3.30 Volts [0xCE] (VSB3V)
     Voltage 8   3.31 Volts [0xCF] (VBAT)
     Temperature 0   46°C (114°F) [0x2E] (TMPIN0)
     Temperature 1   58°C (136°F) [0x3A] (TMPIN1)
     Temperature 2   25°C (77°F) [0x19] (TMPIN2)
     Fan 0   844 RPM [0x6F1] (FANIN0)
     Fan 2   1032 RPM [0x5AD] (FANIN2)
     Fan PWM 0   41 pc [0x69] (CPU)
     Fan PWM 1   65 pc [0xA6] (System Fan 1)
     Fan PWM 2   100 pc [0xFF] (System Fan 2)
Hardware monitor   AMD ADL
     Voltage 0   0.90 Volts [0x384] (VIN0)
     Temperature 0   29°C (84°F) [0x1D] (TMPIN0)
     Clock Speed 0   100.00 MHz [0x64] (Graphics)
     Clock Speed 1   301.00 MHz [0x64] (Memory)
PCI Devices
Description   Host Bridge
Location   bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x5A14
     Revision ID   0x02
Description   System Device
Location   bus 0 (0x00), device 0 (0x00), function 2 (0x02)
Common header
     Vendor ID   0x1002
     Model ID   0x5A23
     Revision ID   0x00
Description   PCI to PCI Bridge
Location   bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x5A16
     Revision ID   0x00
Location   bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x5A18
     Revision ID   0x00
Description   IDE Controller
Location   bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x4390
     Revision ID   0x40
Description   USB Controller (OHCI)
Location   bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x4397
     Revision ID   0x00
Description   USB 2.0 Controller (EHCI)
Location   bus 0 (0x00), device 18 (0x12), function 2 (0x02)
Common header
     Vendor ID   0x1002
     Model ID   0x4396
     Revision ID   0x00
Location   bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x4397
     Revision ID   0x00
Location   bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
     Vendor ID   0x1002
     Model ID   0x4396
     Revision ID   0x00
Description   SMBus Controller
Location   bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x4385
     Revision ID   0x42
Location   bus 0 (0x00), device 20 (0x14), function 1 (0x01)
Common header
     Vendor ID   0x1002
     Model ID   0x439C
     Revision ID   0x40
Description   Multimedia device
Location   bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
     Vendor ID   0x1002
     Model ID   0x4383
     Revision ID   0x40
Description   PCI to ISA Bridge
Location   bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
     Vendor ID   0x1002
     Model ID   0x439D
     Revision ID   0x40
Location   bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
     Vendor ID   0x1002
     Model ID   0x4384
     Revision ID   0x40
Location   bus 0 (0x00), device 20 (0x14), function 5 (0x05)
Common header
     Vendor ID   0x1002
     Model ID   0x4399
     Revision ID   0x00
Location   bus 0 (0x00), device 21 (0x15), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x43A0
     Revision ID   0x00
Location   bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x4397
     Revision ID   0x00
Location   bus 0 (0x00), device 22 (0x16), function 2 (0x02)
Common header
     Vendor ID   0x1002
     Model ID   0x4396
     Revision ID   0x00
Location   bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
     Vendor ID   0x1022
     Model ID   0x1600
     Revision ID   0x00
Location   bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
     Vendor ID   0x1022
     Model ID   0x1601
     Revision ID   0x00
Location   bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
     Vendor ID   0x1022
     Model ID   0x1602
     Revision ID   0x00
Location   bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
     Vendor ID   0x1022
     Model ID   0x1603
     Revision ID   0x00
Location   bus 0 (0x00), device 24 (0x18), function 4 (0x04)
Common header
     Vendor ID   0x1022
     Model ID   0x1604
     Revision ID   0x00
Location   bus 0 (0x00), device 24 (0x18), function 5 (0x05)
Common header
     Vendor ID   0x1022
     Model ID   0x1605
     Revision ID   0x00
Description   VGA Controller
Location   bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID   0x1002
     Model ID   0x6759
     Revision ID   0x00
Location   bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
     Vendor ID   0x1002
     Model ID   0xAA90
     Revision ID   0x00
Location   bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID   0x1B21
     Model ID   0x1042
     Revision ID   0x00
Description   Ethernet Controller
Location   bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID   0x10EC
     Model ID   0x8168
     Revision ID   0x06
DMI
DMI BIOS
     vendor   American Megatrends Inc.
     version   V2.8
     date   01/08/2016
     ROM size   8192 KB
DMI System Information
     manufacturer   MSI
     product   MS-7693
     version   2.0
     serial   To be filled by O.E.M.
     UUID   {FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF}
     SKU   To be filled by O.E.M.
     family   To be filled by O.E.M.
DMI Baseboard
     vendor   MSI
     model   970A-G46 (MS-7693)
     revision   2.0
DMI System Enclosure
     manufacturer   MSI
     chassis type   Desktop
     chassis serial   To Be Filled By O.E.M.
DMI Processor
     manufacturer   AMD
     model   AMD FX(tm)-8150 Eight-Core Processor
     clock speed   3600.0 MHz
     FSB speed   200.0 MHz
     multiplier   18.0x
DMI Port Connector
     designation   J1A1 (internal)
     designation   PS2Mouse (external)
     port type   Mouse Port
     connector   PS/2
DMI Port Connector
     designation   Keyboard (external)
     port type   Keyboard Port
     connector   PS/2
DMI Port Connector
     designation   J2A1 (internal)
     designation   TV Out (external)
     connector   Mini Centronics Type-14
DMI Port Connector
     designation   J2A2A (internal)
     designation   COM A (external)
     port type   Serial Port 16550A
     connector   DB-9 male
DMI Port Connector
     designation   J2A2B (internal)
     designation   Video (external)
     port type   Video Port
     connector   DB-15 female
DMI Port Connector
     designation   J3A1 (internal)
     designation   USB1 (external)
     port type   USB
     connector   Access Bus (USB)
DMI Port Connector
     designation   USB2 (external)
     port type   USB
DMI Port Connector
     designation   USB3 (external)
     port type   USB
DMI Port Connector
     designation   J9A1 - TPM HDR (internal)
DMI Port Connector
     designation   J9C1 - PCIE DOCKING CONN (internal)
DMI Port Connector
     designation   J2B3 - CPU FAN (internal)
DMI Port Connector
     designation   J6C2 - EXT HDMI (internal)
DMI Port Connector
     designation   J3C1 - GMCH FAN (internal)
DMI Port Connector
     designation   J1D1 - ITP (internal)
DMI Port Connector
     designation   J9E2 - MDC INTPSR (internal)
DMI Port Connector
     designation   J9E4 - MDC INTPSR (internal)
DMI Port Connector
     designation   J9E3 - LPC HOT DOCKING (internal)
DMI Port Connector
     designation   J9E1 - SCAN MATRIX (internal)
DMI Port Connector
     designation   J9G1 - LPC SIDE BAND (internal)
DMI Port Connector
     designation   J8F1 - UNIFIED (internal)
DMI Port Connector
     designation   J6F1 - LVDS (internal)
DMI Port Connector
     designation   J2F1 - LAI FAN (internal)
DMI Port Connector
     designation   J2G1 - GFX VID (internal)
DMI Port Connector
     designation   J1G6 - AC JACK (internal)
DMI Extension Slot
     designation   J6B2
     type   A5
     populated   yes
DMI Extension Slot
     designation   J6B1
     type   A5
     populated   yes
DMI Extension Slot
     designation   J6D1
     type   A5
     populated   yes
DMI Extension Slot
     designation   J7B1
     type   A5
     populated   yes
DMI OEM Strings
     string[0]   To Be Filled By O.E.M.
DMI Physical Memory Array
     location   Motherboard
     usage   System Memory
     correction   None
     max capacity   32768 MBytes
     max# of devices   4
DMI Memory Device
     designation   A1_DIMM0
     format   DIMM
     type   unknown
     data width   64 bits
DMI Memory Device
     designation   A1_DIMM1
     format   DIMM
     type   unknown
     data width   64 bits
DMI Memory Device
     designation   A1_DIMM2
     format   DIMM
     type   unknown
     data width   64 bits
DMI Memory Device
     designation   A1_DIMM3
     format   DIMM
     type   unknown
     total width   64 bits
     data width   64 bits
     size   8192 MBytes
Graphics
Number of adapters   1
Graphic APIs
API   ATI I/O
API   ADL SDK
Display Adapters
Display adapter 0
     Name   AMD Radeon HD 6570
     Board Manufacturer   XFX Pine Group Inc.
     Memory size   2 GB
     PCI device   bus 1 (0x1), device 0 (0x0), function 0 (0x0)
     Vendor ID   0x1002 (0x1682)
     Model ID   0x6759 (0x3191)
     Performance Level   0
         Core clock   100.0 MHz
         Memory clock   301.0 MHz
     Performance Level   1
         Core clock   400.0 MHz
         Memory clock   667.0 MHz
     Performance Level   2
         Core clock   650.0 MHz
Win32_VideoController   AdapterRAM = 0x80000000 (2147483648)
Win32_VideoController   DriverVersion = 15.301.1901.0
Win32_VideoController   DriverDate = 02/26/2016
Monitor 0
     Model   T24C301 (Samsung)
     ID   SAM0AD3
     Serial
     Manufacturing Date   Week 3, Year 2013
     Size   23.4 inches
     Max Resolution   1920 x 1080 @ 60 Hz
     Horizontal Freq. Range   15-81 kHz
     Vertical Freq. Range   24-75 Hz
     Max Pixel Clock   230 MHz
     Gamma Factor   2.2
Software
Windows Version   Microsoft Windows 10 (10.0) Home 64-bit (Build 10586)
DirectX Version   12.0
christian.retamal.h
¿nadie responde? :'(
