Msi MPG B650 EDGE WIFI RAM not working as intended
migueldl38158202e1
New member
Joined
Feb 22, 2024
Messages
1
I've built a new pc and it will only boot with only one of the RAM sticks installed
Specs:
- Ryzen 5 7500F
- Msi MPG B650 Edge wifi
- 2x16gb Team Group 6000 MHz CL30 (FF4D532G6000HC30DC01)
- GTX 1050 Ti
- Thermaltake toughpower gf1 750w
- Thermalright PA 120 se
- 1 SSD and 1 hdd both sata
- Windows 11
I believe both of my RAM sticks are ok since the system boots as usual with either one or another installed as long as they are alone and as long as they are installed in slots A2 or B2. It will work at default 4800 MHz or 5600 MHz (Expo profile 2). Not at 6000 MHz.
When having installed both sticks of RAM the system will only boot if they are strictly installed in slots A1 and A2 at default 3600 MHz. Otherwise the pc wont boot. Usually the red CPU and orange dram leds light up at the start and quickly turn off, but then the Orange led lights up again and nothing more happens.
Sometimes both red and Orange leds just stay on. I'm using the last non-beta version (released on 20-02-2024).
I've tried the previous non-beta bios version (from nov 23) and the one thats listed with my CPU model in the board's qvl list. My RAM model also is in the board's qvl list. I've also tried waiting in case the memory training takes long time, cleaning the CMOS, loosening the CPU cooler and checked the CPU socket pins (they seem alright).
Is there anything im missing or anything else i can try?
Thank you
Specs:
- Ryzen 5 7500F
- GTX 1050 Ti
- Windows 11
When having installed both sticks of RAM the system will only boot if they are strictly installed in slots A1 and A2 at default 3600 MHz. Otherwise the pc wont boot. Usually the red CPU and orange dram leds light up at the start and quickly turn off, but then the Orange led lights up again and nothing more happens. MyOLSD
Thank you
Ensure BIOS is up to date, try adjusting RAM timings manually, and verify if XMP profiles are supported and configured correctly.
That sounds frustrating. Hopefully the RAM issue can be resolved with the right BIOS settings and testing; regular CLEANING and maintenance can also help keep PC components in good condition.
Back
Top
